64 bit 33mhz pci sata controllers
27 Apr 2007
First of all, Hi, first post!
Ive got an ml310 t01 (glorified workstation, server), I want to run two 250gb sata drives, my main problem is that I cannot find any 64bit 33mhz pci cards that look like they will fit and do the job. Basically the server is going to be used for pushing out ghost images occasionally to our developers to test new software on, has anyone done anything similar? I could also go down the firewire card or usb 2.0 if necessary but again because this server is a few years old its proving quite difficult to source options for, if it had been pci-x etc it wouldnt have been any problem at all.
Any advice would be great.
