64 bit issues with CPU's
The only ones you might have trouble with, or won't perform correctly are Pentium dual cores when the extensions were a bit of an afterthought. Any Core 2 or newer should be fine as already said.
Just to clarify that Alex is referring to the Pentium D series here. The Current line of Pentium Dual Core should be fine.
(Am I right in that, that is what you mean Alex?)
