64 bit Vista
15 Jul 2005
UK
Hi all,
When Vista comes out, do you think most people will buy the 64 bit version? I know that a 64 bit version of XP is out, but nobody uses it as their is hardley no software, and the drivers still need maturing a bit.
Do you think that Vista will kill off 32 bit and everyone will go 64? or do you think theres still a few more years for 64 bit CPUs to be used properly?
You get both the 32bit and 64 bit version of Vista when you buy it. Iirc.
But if it is a choice I'll be getting the 64 bit one.
is there? ah thats good. There needs to be more 64 bit apps on the market, running them in emulation mode is more of a workaround than anything.
Does anyone know a list of future apps that will \ are 64 bit?
The only game I know thats 64 bit is UT2004\7
