snowdog said:Guys, whatever you do, always renember: ddr= double data rate.
What you see in cpu-z always has to be multiplied by 2.
ie. 400 = ddr800 speed...
Almost any high performance ram needs more volts then the automatic 1.8 volt, set it manually to 2.1-2.2 volts.
The ram divider is how fast the ram runs compared to the front side bus, ie. on fsb:ram = 4:3 the ram runs on 3 mhz if the fsb runs on 4, ram 6mhz if fsb at 8 mhz, same calculation for any other divider.
Thanks
