6400C5 / 6400C4
21 Oct 2006
Corsair 1GB DDR2 XMS2-6400C5 TwinX (2x512MB) (MY-112-CS) /
Corsair 1GB DDR2 XMS2-6400C4 TwinX (2x512MB) (MY-111-CS)
How do you guys recon this would fair with the DS3 & C2D E6300 and which of the two would you go for ?
Cheers.
Cheers.
Price range?
It depends, do you plan on overclocking or not? If so, how high do you plan to go?
The revision numbers of those two sets can be pretty important, too. Some are made with awesome high-frequency ICs, and some are made with ICs that do better at lower latency.
Overall the 6400C4 is generally better.
if you plan to oc the memory then cas 4, if your gonna run it at stock then cas 5 would be more than fine. Not sure what the average max fsb is on the DS3 mind you, but seen some cracking oc's on it so i would personally go C4.
Well with a DS3 your RAM runs 1:1, so it depends what cPU you have. For instance with my E6400 my RAM is at stock up to 333Mhz FSB using DDR667 RAM. With DDR800 RAM, the RAM would run at stock at up to 400FSB.
Definately the C4. You'll be looking to get your FSB upto 450+ with the e6300 and the C4 would be a far better match.
