64bit downgrade to 32bit
20 Mar 2005
Leicester
Ok im looking to down grade from Vista 64 ultimate to vista 32. My pc currently is set up with the hard drive partitioned into 2 drives.
Can I just copy all my files over to the second partition and format the first one and then re-install vista onto it? Or do I need to format both partitions?
Basically will the install wipe the second partition or is it going to be safe?
Many thanks in advance
