Been getting used to my watercooling loop and wondering if my fan direction is optimal
after two hours of gaming here is my temps for a CPU only loop (240mm rad)
cpu 1: 59c
cpu 2: 62c
cpu 3: 64c
cpu 4: 61c
package: 64c
my ambient temp is 26c , I have two GPU's in the case (that frankly need better cooling now it's warm weather)
GPU 1(top) hit 82c ,
GPU 2(bottom) hit 74c
My fans(GT1850's) pull air from the top of my case as an intake and I have a rear 120mm sucking air out
intake is a 200mm
My theory is that my gpu's are heating up the loop more and the 120mm is hard pressed to dump the heat out the case would anyone suggest turning the top fans over to exhaust and have the rear 120mm as an intake ? I'm concerned if I did that then the heat from the GPU's would make the result all the same
cpu 1: 59c
cpu 2: 62c
cpu 3: 64c
cpu 4: 61c
package: 64c
intake is a 200mm
