Hello Forum, First post, so be gentle!! I am going to get a Gigabyte Aorus Master and I need 64GB RAM for the work I do at home. Yes, I do need 64GB for the VMs that I run. I have hit an absolute memory minefield and I would appreciate some steer in the right direction. I would like low profile modules if I can and I believe that 4x16GB modules would be cheaper that 2x32GB. For this reason I like the Corsair LPX Vengeance series The problem I am having is the following:
1. The QVL for 16GB Corsair modules on the Gigabyte QVL states that the CMK32GX4M2D3200C16 Vengeance LPX 32 GB (2 x 16 GB) is on the list. However, when I look at the specs on the Corsair site it states compatible with Intel. Surely, RAM is RAM or is it just the XMP profiles that are guaranteed to work with Intel? So my first question is would this RAM be the first choice?
2. I see that there is AMD "optimized" RAM Corsair SKU CMK32GX4M2Z3200C16, This seems the obvious choice as it is tuned for AMD. On the Corsair website it states that it is X570 supported. It ticks all the boxes, but its not on the QVL. Doubt sinks in.....
Ideally, I think these would do the trick: https://www.overclockers.co.uk/corsair-vengeance-lpx-64gb-2x32gb-ddr4-pc4-28800c18-3600mhz-dual-channel-kit-black-my-4cf-cs.html
3. Are there an other vendors that would do the same? Requirements are pricing of around £300, and personally I would like 2x32GB sticks instead of 4x16GB (but 4x is ok at a push), but I do not know if any are in budget?? I do not overclock, but want a system stable ie it could run memtest86 all day long and pass. I have not got time to mess around with the setups like I could in my younger days- I just want to purchase something at Overclockers that can put in and it just works 100% compatible.
Turned into a long thread- sorry!! And a Happy New Year
xmal
xmal
