64GB White RAM?
30 Dec 2005
Hi all,
Looking to change my ram to some white modules to match my system, currently have 2 x 64GB Corsair LPX.
I have a 3900X at the moment, would the Corsair Vengeance RGB PRO SL White (4x16) 64GB 3200MHz to as good or better?
Thanks
Hi all,
Thanks
What do you want to do with it?
what’s happening with your current RAM that isn’t working for you?
I can’t imagine you’d see much improvement in performance over your current RAM as your current kit is more thank likely dual rank.
I’d suggest you spend your hard earned money on a 5900X or 5950X. It would be a better use of your money.
