650D Build
21 Aug 2007
Hey all,
Just thought I'd post my customer loop I finished a couple of days ago. It's built inside Corsair's 650D case (although I'm already thinking about the 900D).
Spec's of my PC and Water Cooling are:-
Intel 3770K CPU @ 4.5Ghz (1.185v)
16GB Patriot RAM C9 DDR3
Gigabyte GAZ77-UD5H Board
2x EVGA 670GTX FTW [2GB Models]
2x 120GB Intel 330 SSD's in RAID0
1x 1TB Samsung F3 Spinpoint
Corsair TX750M PSU
Dell 24" U2410 IPS Monitor
Water Cooling Components
Radiators: 1x GT Stealth Black ICE 280MM, 1x 200MM Phoyba
Reservoir: Bitspower z-multi 150mm
Pump: XSPC D5 Vario Pump & EK-D5 X-TOP CSQ Plexi
Tubing: XSPC 1/2" ID 3/4OD
Fittings Bitspower Black Sparkle Compression/Rotary/Dual Rotary/Extenders
CPU Block: XSPC Raystorm
VGA Blocks: XSPC Razer
SLI Bridge: XSPC SLI Bridge
Fluid: Mayhems Pastel Blue
I still have some work to do on the system
- tidy up the bottom area near lower res
- Add some lighting
- Add a Corsair Link Fan/Lighting Controller
Just thought I'd see what you guys thought? Cheers for all the people who helped me set this up and work out the bugs....
The pictures aren't that great but I'll try and get some more done to make it look a bit more glitzy. :/
Looks really good and tidy!
You must have seen the 650D watercooling youtube video? almost exactly the same minus the drain line between pump and 200mm rad. I Like the copper CPU and the XSCP GPU blocks and bridge.
How are your temps now?
What fan you using on the 200mm?
Looks very nice, if you have any more money (and time!) I suggest you look into doing some custom cable sleeving. It has been scientifically proven that custom cables make computers look 50% more badass. But great job!
