Did you mean 660ti? There's no comparison in performance between 650ti and 7870. The 7870 is leagues ahead.
There's quite a big difference in most games, e.g. BF3 ultra - 660ti Boost 45fps, 7870 stock 59fps. Sleeping Dogs very high - 23fps vs 32fps.
It's really between the 7790 and 7850 (benchmarks put it slightly below a 7850), the 7870 outclasses it comfortably.
Yup, but that model is already quite highly overclocked, so it's not a fair comparison against a reference 7850.
What you guys think of this one here : http://www.overclockers.co.uk/showproduct.php?prodid=GX-185-MS&groupid=701&catid=56&subcat=411
It'd be fine, yeah. If you have a bit more to spend I'd try to stretch to a 7950 with the mega bundle, and sell the games you don't want.
Yeah, I think that an OC'd 650ti is a good buy, and AMD needs to drop the price on the 7850s.
Also, since the 7850 and 70 are slightly older cards, almost all the benchmarks are 2012, and driver performance is massively better since then. The initial 7000 drivers were a bit crappy.
MSI GeForce GTX 650 Ti BOOST OC review - Article
Posted by Hilbert Hagedoorn on: 05/03/2013 08:18 AM
I'll leave you with this,
Which nobody really sells. A maxed out 650ti Boost wouldn't match a maxed out 7850, but then the latter does cost more.Thats about as high as I can go with money at the moment.
What are the drivers like these days?
I heard they were pretty bad before with the 7870s![]()
Yup, they were a bit rough last year when they came out but they've been fine for a while now, and improving with each release.
MSI's cards tend to be very good whatever the GPU so you're probably fine with that one.
