They are voltage locked
You know you can overclock without touching the voltage?
This is probably your best bet as you can find the cards limit and then adjust from there.
The 1.21V will do no harm at all and others have reported a 50Mhz increase in core clock.
Ok thanks Gregster,
Thats great news
So just to confirm that i'm still ok to turn up my voltage in msi afterburner for core and memory by +100mv???????
Ps I know you like your 3dmark11 scores so here is one my mate just sent me on his first run with new bios.
Graphics of over 10000 on first run is promising
http://www.3dmark.com/3dm11/5205878
I will post my scores soon but 3dmark11 and vantage have stopped working (not sure why).
You will get better stability and those voltages are more than safe. Keep an eye on temps of course
Hi Rusty,
Yes I can get a nice overclock without touching voltage.
Was just wanting confirmation on whether or not the 1.2v bios is safe to use?
And is it ok to still adjust the core voltage in msi afterburner with new bios installed?
Thanks![]()
.Yes perfectly safe.
Apply max voltage and then just find your highest stability point. Do the core/memory separately ideally but there's no harm doing both together.
Just keep an eye on the temps.
No probs and I have to be honest and say how impressed with that score I am. My stock 680 only just manages that. I didn't expect those cards to give that kind of return. Very impressed and if Nvidia would just chop £20 off the price, I can start recommending them![]()
