660ti upgrade ?7`s 9`s
16 Sep 2012
Hi guys i think it time for my asus 660ti to get a upgrade.
what series would you guys go for,ive been looking at 780 and 970 MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £279.95 inc VAT
il be using the card for bf4 mainly i will be playing at 1080p as my monitor only supports 1080p max ;-0
budget 300
970 seems your best bet as its well inside your price range, excellent for 1080P and you cannot ignore the better power usage you get with it.
gonna go with the Gigabyte
GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card
out of stock here right now but i can wait a little longer ,thanks guys
No problem, I've got the Gigabyte one and it's a great card but make sure you have enough space on your case because its a bit over 30cm long.
