670 major problem
Exe
Exe
17 Nov 2011
Hello, basically i fitted an accelero hybrid to my 670gtx booted into windows then i ran heaven i think it was the driver crashed or so and i lost display so i restarted. Since then ive been unable to get display from it, any ideas?
Can you see the boot screens before windows?
If yes, were you overclocking the 670 and ticked an option that applys overclocking at system startup?
First thing i'd do then is check for any horrific scenarios like a leak.
If no leak, remove the new cooler and check you applied it properly. Put the stock cooler back on and see if the card is utterly borked or not. If not borked, try mounting the new cooler again.
Idk how the pump on this gets it's power, it's definitely cabled up, and was pumping?
heatsinks was on fine, when it worked the temps were all correct etc. Theres no leaks also as ive checked for bits like that and pump etc is all wired up properly
Any beeps?
Does the cooler fan spin?
Try a different GFX card in the same slot ideally using the same power leads.
If that works then it looks bad for the card.:(
What temps were you monitoring? Maybe just the GPU core? Maybe a badly fitted VRM heatsink and its cooked the VRMs?:(
