6700k ddr3 or 4
1 Jun 2012
UK
Hi, my 3770k is getting a little old now and I'm thinking it's time to upgrade however budget is a tad tight so what I'm wondering is will there be much performance loss with the components below and the DDR3 ram I already have or would I be better off spending the extra 100ish quid and going for DDR4
YOUR BASKET
1 x Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail £329.99
1 x Asus Z170-P D3 Intel Z170 (Socket 1151) DDR3 ATX Motherboard £82.99
Total : £422.58 (includes shipping : £8.00 Ex.VAT).
It's more about size than anything else and it's swings and roundabouts with speed vs latency, if budget is tight you can maybe keep your ram, I think it has to be DDR3L ram thought rather than normal DDR3, but you should check that.
