Not sure if there is really so much worth posting this but why not try, you never know when you've missed something that might save the day...
HELP MEEEEEE.
I've got a 6700k, i've had it about a year and a bit now and its currently delidded in a custom loop. My base hardware is:
In terms of cooling, hear is not a problem and everything is in a custom loop with more cooling that sensible. To head off any questions its currently cooled by 4 radiators all HWL Black Ice (60mm thick), 240mm x 2, 360mm x 1, 480mm x 1 cooled by far too many Corsair mag levs (17 to be precise). Anyway... So temps are fine, nothing ever gets over 45-48 in tests with the 4.5 OC working fine about 1.28v. GPUs will not exceed about 33c even when running quite well overclocked.
What the issue is that I literally can't do any more, now you might say well its just a crap chip - BUT originally in my old build it ran happily at 4.8, 24/7 I ran 4.7. I've tried as much as I can think of, but here's a rough list - no matter what it blue screens almost immediately with the WATCHDOG_CLOCK error when any test starts. I can run the 'stress cpu' in CPUz no worries but anything like x264 or Cinebench is an instant fail.
Any ideas of things to check before I just give in and live with 4.5 until I replace it?
Cheers!
HELP MEEEEEE.
- 6700k, delid and CLU under the freshly lapped IHS
- RAM: Corsair Vengeance 3000mhz DDR4 x 4 (32GB total)
- Mobo: Asus Z170 Deluxe, modified but only cosmetically
- 2 x EVGA 1080 FTW
- Corsair H1200i PSU
- Voltage, obviously but i've tried up to 1.45v - temps absolutely fine again the cooling is quite something
- BIOS Update, no different
- RAM: XMP or Stock (2133), no difference
- Various power management settings in the Asus BIOS, setting things to extreme, disabling anything that should be for 'overclocking' - can't see anything which might be causing it
- Power Control set to 130% to allow greater tolerance of the voltage (as far as I understand)
- LLC: few different ones, set to 5, no difference over auto
Cheers!
