6700K OC (Voltage)
See what it increases to on load. I've got LLC control on high so mine pretty much doesn't move from 1.375v
Unfortunately on my MSI motherboard LLC is pretty useless as it has auto or mode 1 and mode 1 really does not seem to do anything.
Just monitor it under load. A couple of minutes won't hurt (some people are running then at 1.45v anyway).
i use 1.35 on my 6600k, i just got an 6400 for the boy and i think 1.35 will be the most i try it on. temps on my chip are fine under normal load(game)
i cant see you having a problem with an extra 0.04v
i have the same board its poo for overclocking but tbf its a gaming board not an overclocking board.
Atm i am at 4.6Ghz with 1.320V and an offset of -0.020, i use the offset because while using adaptive mode it knocks my voltage under load up by about 0.028v
tbf i would be happy with that speed at that voltage
what sort of temps do you see
After hours of gaming:
While my PC was idle it BSOD'ed, i think the offset is taking to much voltage as i was only attempting to use it for the over voltage from adaptive mode.
Adaptive no need just use fixed.
1.4 is about max on ambient.
That is a decent CPU, what memory and cache speeds???
after delidding my 6600k, I run mine @ 4.8ghz with 1.4 volts - temps only reach about 55 degrees on corsair h100. Dials down on idle though
