- 4 Nov 2013
Hi all,
I get a black screen crash while I play battlefield 5 / God of War / Assassins Creed Valhala, the black screen will last for around 5 seconds then the computer will automatically restart.
Most of the time it happens randomly, but it keep happening during the last boss fight + cut scene in God of War so I am stuck in that loop.
It could crash any time during the actual fight or the cut scene after that, totally random.
And it never happen in FIFA22.
Then when I check Event Viewer I found:
WHEA-Logger 18, Cache Hierarchy Error, Processor APIC ID: 1 to 13 (yes after so many crashes I have got crash report on all 13 of them)
Kernel-Power 41, task 63.
I used DDU to unstall and reinstall both GPU and sound card driver.
updated the mother bios to the latest non beta version
No overclock on cpu and gpu
disable XRP
Have tried both Ryzen 3600 and Ryzen 5600X
Both cpu and gpu temp are around 70c.
when it crash the RGB light on my motherboard, graphic card and case are all on
After so many crashes I have swaped my 6700XT to my old R9 Fury, then it didnt crash during the boss fight + cut scene, tested it for 5 times and no crash.
Below is my spec:
Ryzen 3600 / 5600X
MSI B450 TOMAHAWK MAX
Sapphire NITRO+ AMD Radeon RX 6700 XT 12GB GDDR6 Graphics Card
Kingston Fury Beast 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit
EVGA SuperNOVA 750 G2, 80+ GOLD 750W
Crucial MX500 CT500MX500SSD1 500 GB
Thanks for reading!
I totally dont know what to do so any help would be much appreciated! THANKS!
disable XRP
Below is my spec:
Ryzen 3600 / 5600X
Thanks for reading!
