but the i7 920 uses more juice
Not you - wunkley. Sandy Bridge is more power hungry but not a massive amount.
This is the bit that got my attention. An extra 205W going from 4.6 to 5.0Ghz
That includes overclocking the cards as well
power 131%
+85 on the cores
+490 on the mem
Also 24/7 was cards @ stock
I'll double check to make sure the values are correct and let you know.
Knowing me I probably screwed up![]()
Phew thats a relief
Its safe for me to go ocing again.![]()
There was a discussion a while back regarding the power draw of 2 Kepler cards in SLI and there was talk of needing an 850W PSU "to be safe" and that you will run close to the limit with 750W and as such limit the life of your PSU.
Well I have just tested with a power monitor and with both cards fully going for it with 99% usage in BF3 in Surround, power usage was:
450W
While I can clearly see and agree with the argument that you should buy a good quality PSU, to say you need greater than 750W is incorrect as even with 750W there is a large headroom there.![]()
cards are becoming more efficient, but now I feel I've wasted money buying a Seasonic because of advise on here![]()
I can remember someone on here running gtx 470's on an sb based system, cards were at the same clocks as mine in my old 920 rig, pretty similair range of other components. Iirc, the guy stated a total power draw at the wall of 600w, 30 less than my setup when gaming.but the i7 920 uses more juice
The problem is people don't actually test it before they advise and advise in a way that makes their advice sound completely authoritative.
You should always get a good PSU though, that's undoubted.
I left my power monitor while gaming for about 3 hours and then checked the "max" recorded on it. It was 520W. And that is with the rig in my signature all with overclocks on. Every time I looked it was around 430-470W though.
though.
Got a power monitor and from the wall with everything overclocked (5GHZ CPU @ 1.495V + 680 LTG SLI @ 1346mhz), my power usage is hitting 800W
I think I need to upgrade my PSU![]()
800w @ the wall is always more than what the psu is actually using. If your psu is 85 percent efficiency your system is using 680w.
That's very high still, to be expected though with those overclocks.
Yep and my concern is when I get my 680's under water, I will be pushing them higher than the 1.2120V I currently have.
