6800GT Fan
18 Nov 2004
Bournemouth
It looks as though the fan on my 6800GT has stopped working. Is there anything i can do? Anything to check? Or is it now b0rked forever? :(
If its really broke you can fit a nice NV silencer for like £14, I dount it is card, fan is probably done.
Not under warrenty ?.
Often seized bearings or bush. You might be able to remove the fan and oil the bearings with very light oil for a temporary repair but arctic cooler is much better idea
Ah yes, totally forgot about an arctic cooler. That's saved me a lot of bother, thanks :)
