It uses less power, runs cooler, clocks better and is faster at stock than the 6800GT. No contest.
Minstadave said:Second hand cards are cheap, the MM has a £75 7600GT at the moment, not bad at all![]()
semi-pro waster said:I would ask how much either or both would be costing you though? If there is a gap of any more than say £15-20 I'd just buy the 6800gt because the 7600gt isn't that much better, at least not worth paying an extra 20% for in my view.
Also can I ask why you are replacing a 6800? It might be that you are better considering upgrading another area of your system first.![]()
)and an ASUS V999 (128mb 6800) on an ASROCK mobo
Target said:Oblivion is my main game at the moment. Would I be better getting an x1650xt?
man_from_uncle said:No. They are rubbish. Well, not rubbish, but not good value compared the to 7600gt.
x1650 XT (£99) is cheaper than the 7600 GT (£105), and its slightly faster LoadsaMoney said:Ehx1650 XT (£99) is cheaper than the 7600 GT (£105), and its slightly faster
here , so hows that not good value, plus its better in Oblivion which is his main game, plus its got better image quality and can do AA+HDR.
man_from_uncle said:Fair enough. I've been out of the loop a bit on the X1650XT, I assumed it was just another weak follower from the X1600 family.
Ignore what i said. If it's good it's good.
FoxEye said:I have a 6800GT, and believe me you'll need better than that to run Oblivion
I'd question the wisdom of spending £75 when the difference in speed from a 6800GT to the 7600GT isn't going to be much at all. Double your money and you could get a 1950pro or 7900GS, and you would definitely see the difference then!
FoxEye said:Haven't seen many GTO about, and when I do see em, they're going for close to £200!
