I'm currently running a Leadtek 6800GT. I don't usually pay much attention to the temps but recently, the system has started to become very unstable when running games or anything that is graphically intensive.
GPU Core temp is at 87ºC on idle with an ambient temp of 65ºC. Running a random game for 5 minutes will take the GPU Core temp to 117ºC or higher though the system would have probably crashed by then. The card is running at stock speeds, never overclocked either.
My system ambient temp is only 29ºC, CPU averaging 40ºC so am I right to assume something is wrong with the 6800GT (it ticks all the boxes in my mind but I'm no expert with graphics card temps)?
It's only a year and a half old (half way through its 3 year warranty), time for a RMA? If yes, does anyone know how to contact Leadtek apart from their Netherlands number?
or can I be cheeky and RMA it off to OcUK?
Would the Artic Cooling Accelero X1 be a better solution rather than trying to faff around trying to go through warranty or cleaning up whatever is causing the heat build-up?
