6800LE Help
18 Oct 2002
Stoke-on-Trent
If I have a 6800LE which unlocks to 6800NU (12pipes etc) using rivatuner, would it be ok to flash the bios using a 6800NU bios file and will this unlock the pipes etc without having to use rivatuner?
Sorry for the noobie question :confused:
yea you could flash it, also do a volt mod on it at the same time. the le runs the core at 1.1v the nu does 1.2v the gt does 1.3v and the ultra does 1.4v. best to not go over 1.3v it will be safer. also with less active pipe lines you should be able to get a good overclock on the core with stock volts.
have you tried onlocking the rest of the pipes and shaders, i found that if you try with diff combo's i managed to get my LE to 16 pipes and 5 shaders which makes it 1 shader short of an ultra
noob question were can i get these bios files as id like to up the volts on my 6800 le as it unlocks to an ultra and clocks very high 420 core 980 mem too at the stock 1.1 volts so i,m thinking at 1.3v it would fly
new to 6800 LE's
new to 6800 LE's
I found loads of bios files on this site > http://www.mvktech.net/ (look in the download section)
Extra voltage will definitely help. I couldn't overclock my 6800LE after opening up the hidden pipelines and shaders. After I flashed my card with a new bios I managed to overclock it no problems.
