6800XT browser issue.
4 Apr 2004
Manchester
Hi people.
Just a quick one. Since i've got my 6800XT i've noticed that when I scroll on, say Youtube, when a video is playing, the screen (whilst the video is still in view) is all jerky, but as soon as the video has scrolled off the screen it goes perfectly smooth. If I turn "use hardware acceleration" off, it works perfectly, so I'm fairly sure it's a graphics card setting.
Any ideas? Is this an obvious setting I'm missing?
Not seeing that here on a 6900XT, what browser are you using? Is it up to date? 21.2.3 AMD driver?
It's on all browsers. I've not updated to the very latest drivers. I'm starting to think I may have altered one of the free sync options (in my attempts to get smooth gameplay) and this is causing it. It's my first time using AMD, previously always been Nvidia and that was pretty much just set and forget. I'm probably missing something really obvious, I'll just have to keep messing with all the settings.
If you have time, would it be possible for you to list your freesync/antilag/advanced freesync etc. settings, or maybe post a screenshot. I've been having a load of problems and I'm just not that smart with stuff like this.
Have you tried resetting the driver and monitor settings back to default to test?
I'm going to give that a go tonight. I've had nothing but problems so far (this is almost certainly 99% my lack of knowledge though) getting it to run well and haven't had a lot of free time to iron out issues.
I'm wondering if there is a conflict between all the freesync/VRR settings. I noticed there is a setting in Windows for it and two in the Radeon software.
