6800XT coil whine
24 Jan 2023
Manchester
Hi i bought a B grade 6800XT last month and it's making what I think is coil whine but it's so loud it drowns out the sound of the tv.Customer support got back to me and said it's normal and not considered a fault,but in no way do I think this is normal,it sounds like the card is going to break.
I have attached a couple of videos,but it's so much louder than it shows
That's pretty loud whine, almost certainly why it was returned. Most modern cards have it to some degree or another.
I must be getting old as I cannot hear the whine. Does it happen all the time. If you frame cap to your monitors refresh rate can you still hear it.
It's really loud and I have a LG B8 so it's always capped to 60fps.It happens all the time unless it's a really old game
So it's normal for a card to sound like that? it completely drowns out the sound of the tv,and sounds dangerous.
probably why its b grade cause someone returned it for coil whine, to be fair i also cant really hear anything loud that im not sure isnt fan noise
If it is really audible capped at 60fps then that isn't great.
It is rare to get a GPU that doesn't squeal a bit at really high FPS i have found though.
They asked me to take a video from viewing distance to see how loud it was from there,and within 5 minutes of me sending it they agreed to RMA Unfortunately they can only refund as they have no more in stock,so I don't know what card I could possibly get that is as good as this for £450
With that cash I would go for
https://www.overclockers.co.uk/sapp...ddr6-pci-express-graphics-card-gx-39d-sp.html
It wont be as fast but it is close and you get a game worth 50 quid.
