6800xt low utilisation and fps
30 Jan 2005
Inverness
I bought myself a 1440 165hz monitor to take advantage of my 6800xt but I'm struggling to get more than around 70fps on battlefield V the GPU is only clocking to around 900 core and showing 70% utilisation.
I've tried messing with the chill settings and made sure all the settings in the battlefield menu are set correctly.
Can anyone offer any tips advice?
Thanks
Scott
25% utilisation, found the culprit it needs to have future frame rendering on even with a really strong CPU.
Thanks
Scott
DX12 or DX11? Try both?
has that fixed it? I used to play with it off on my 5820k and Titan x pascal and would get about 100 fps at 1440p (no ray tracing though)
Yeah it went to 160-200fps instantly.
I'll need to see it there's any difference between dx11 and dx12
