It looks like some reviewers don't recommend the 6900XT card.
From what I can see, reviewers are running Cyberpunk2077 with Ryzen 5900X, 32 GB DDR4 3600 ( all top quality cpu and ram components) at only 1080p with Ray Tracing ON and getting 45fps.
I'm concerned that 4k with the 6900XT would likely run at 10fps with Ray Tracing on and DLSS off.
Even the RTX 3070 is beating the 6900XT with Ray Tracing / DLSS on. And the card cost like twice the price of the 3070.
1. Do AMD need to step up for next gen cards? Or is really a 4k gaming card.
2. Is it worth buying a 6900XT over a 3080/3090?
3. Are there 6900XT laptop variants?
4. If you have purchased the AMD cards , would you recommend it and what are the cons of the card?
