6850 Low Furmark FPS?
24 Dec 2011
Basically flat out 42 FPS.
This is on 1280x720; I usually use my monitor at 1440x960 and I only get 30 or so FPS (No AA on)
Is this normal..? As you can see the clock speed is raised from 750mhz to 850, which I did in AMDs CCC.
The score I get in the scored test is only around 950~ which is confusing as I see people getting thousands...?
