I've been keeping my current CPU for a long time at 4.4 GHz at 1.29 Vcore but in the end I pushed for more and tried 4.5 which worked OK, fully stable at 1.334, but for gaming and in cases when it is not running at utilisation above 70-80% at 4.5GHz I am keeping it at 1.324. Gaming for example works great. My motherboard is a Rampage V Edition 10 with 32GB of RAM at 3.2 GHz run in XMP mode. CPU Cache voltage is at 1.15 (reaching 1.16 under load) at 36 multiplier (31 standard if I remember right). CPU input voltage (VCCIO) is manually set to not go above 1.8 and is mostly staying at 1.792 even at full and long-term load. Stable and working OK.
I was feeling comfortable having the CPU run at 1.29 (below 1.3 Vcore), but now since I am at fully manual mode and to be honest having some in moments hard time to properly fine tune it, I feel a little cautious about staying at 1.324 at all times. Anyone running their 6850K (Broadwell-E) chip at 4.5GHz 24/7 in manual mode? If so, at what settings? Anyone using adaptive voltage (Vcore) and if so, is it safe at load? It is not that I couldn't try adaptive mode but first do not really have the time to test and am also concerned the motherboard irrespective to the settings will push even higher voltages under load. I am running a 1080Ti factory overclocked edition and when gaming a few days ago at maximum game settings the PC rebooted and upon booting I will hear three or four motherboard beeps (1 long and 3 short) which from checking meant "no VGA" found. I turned the PC off the grid, waited for a while, and turned it back on, resulting in a proper operation but until I turned the PC off completely again, before Windows lock screen (and even in Windows for seconds) I can see a square blue artifact on the very top of the monitor which made me think the card is gone. So these fine-tuning re/sets/starts sometimes are not safe at all and may lead to damage to any components, especially around the edge of the silicon's sweet spots.
My CPU LLC (load-line calibration level) is 7 out of 11 if I remember (but Asus BIOS maximum recommended one for overclocking).
So, any suggestions? Will 24/7 running this CPU at almost 1.33 vcore (all cores synched) be OK? Shall I go for adaptive mode instead and is it recommended from personal experience? Don't get me wrong, most of the time computer is operating at 1.2GHz browsing, watching stuff, doing different work with real loads relatively rarely (10-15% of the time). So far the CPU never throttled or reached even 90 degrees Celsius, even once, including the CPU package. Most of the time CPU and CPU core temperatures stay well below 70-72 under load (like in their high 30's), up to maximum 80 for short time. But the cores run at almost 1.33, even at 1.2GHz and no load whatsoever...
Thanks for any suggestions.
