6850K vcore
21 Jan 2008
Northwood, London
Bought the Titan Tornado from good old OcUK (rig in sig) a couple of months ago and just wondering what the lowest vcore I can get without BSOD's? At the mo it's at 1.241 (@4.2Ghz) and from I can remember (getting on a bit so bear with me) was to lower it by .25 each time. But rather than do this and potentially taking a wee while, is there a minimum I can get it to and then have play around with it a little? I haven't done a massive amount of fiddling around (no pun intended) due to being content in the past, but I thought I'd like to try...any help is greatly appreciated :)
you will have to try that yourself as every chip is different. you could go the other way and set it to 1.1v and go up 0.025v untill it boots :p
Thanks for the advice Jumper, a rough idea was what I needed and I'll start around 1.1v and go from there. Just didn't fancy taking a wild guess and taking an age to get somewhere near lol.
Once it boots remember to stability test it as well. Most people recommend Asus Realbench for newer CPUs.
http://dlcdnmkt.asus.com/rog/RealBench_v2.44.zip
+1 for Realbench - my 6850 boots with 4.2 and 4.3 at voltages which simply don't stand up if you make the CPU do a bit of work...
For what it's worth, disable or close any monitoring or stats software which has an OSD overlay while you run Realbench - I found the OSD from my NZXT cooler 'CAM' software crashed one of the Realbench components, scratched my head over that for a few hours :/
CAM is utter garbage.
At the moment I am having some issues getting realbench to not crash at stock :(
Though it might be caused by openhardwaremonitor or something.
Isn't it just - latest "update" doesn't even load. I was forewarned it's really unstable though so not unexpected. Sounds likely the realbench crash is some other software related, is it Luxmark that dies?
Guys, many thanks for the advice, I'll have a go Fri night and see how I get on and get back to you if I have any drama's.
Thanks in advance.
I've adjusted the VCore to 1.150 (from 1.241V) and it boots ok, then I ran Realbench using 15 min duration and using 4Gb RAM, it detected an instability at the 13 min point (34.50%)...do you think it's worth giving it slightly more VCore then re-run the test? I did play a couple of games Aliens CM and Resi Evil 6 and they work a charm still without any BSOD's (I doubt they tax anything but....).
