Looking at upgrading to a pair of these with the special offer going on, and im just wondering whether my 750w PSU (Xigmatek NRP) would be sufficient and stable running 2x 6870s with a Q6600, or whether i'd need 800w or better to run both.
The PSU has 2x 6-pins, im assuming a good old molex convertor is fine for the other 2x 6-pins it'd require, right? (looks like im a 6-pin convertor short, so would need to buy one if they're not included anymore).
Im just looking to get the best performance gains from my existing setup (Q6600 @ 3ghz, 8gb ddr2, and a 5770) without having to spend in other areas because there just isnt the money, and from what i can tell nothing is pushing the CPU that hard anyway, the GPU has always been the limiting factor. Im also running at 2048x1152 so pixel pushing power is a must, and this seems to far outperform a 6950 which is the only other option in my price range from AMD.
Havent done crossfire before, are there any pitfalls or things i should know before plunging in head first? I know some games dont always like CF, so might be reduced to a single card, but are there other issues i havent read about?
wont be paying £115 at least not while the 6870s are £120.
