6950 (6970) dead, which replacement?
Mud
Mud
13 Dec 2004
Bristol
My ATi 6950 (flashed to 6970) appears to have given up the ghost (28 months old). What's the logical replacement? Really, all I play is a bit of GTR Evolution at ~5000x1600 (3 screens using softTH) which the 6950 did fine. The rest of the system is a Intel [email protected] and 8GB DDR3 running at 1333MHz - I don't really want to downgrade or spend unnecessarily if bottle-necked. Does need 3 digital outputs (2xDVI for Dell 2007FPs, + DVI/displayport for U3011). Quiet is a priority, as is cool-running.
TIA, I've fallen out of the bleeding-edge performance scene :)
7850 or 7870 not sure about a 7950 with that cpu at that speed being okay
Have there been a lot of failures on 7950s?
e: stuff it, 3 year warranty. It can fail if it wants :p
It would still be fine with the CPU at that speed.... >:/
I misunderstood what C64 was getting at - thought he was saying the pre-clocked card was pushing the architecture. I agree, no harm will come from arguably overspeccing the card slightly.
I thought a cpu at 2.8 ghz could bottleneck a 7950 is all, guess I was wrong pretty sure that would bottleneck a 7970 though.
I just don't think the 7950 or 7970 are worth the price tag seeing as they have been out a good while now I wouldn't pay much more than £200 for a 7950.
The msi 7950 is £218 though so I'd get that I guess.
http://www.anandtech.com/bench/GPU12/372 is a good benchmarking comparison site you can compare all the cards 2012 and 2013.
If you want a cheaper option that matches a 6970 then a 7850/7870 would do the job and be faster in newer games.
