- 17 Jun 2005
Hello All,
Just about to push the button on a 6950 and was wondering which one was the best value for money at the moment?
I want a 2GB version and realize they are all mostly the same.
The ones i have been considering due to the attractive price are:-
http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS&groupid=701&catid=56&subcat=1752
or
http://www.overclockers.co.uk/showproduct.php?prodid=GX-192-XF&groupid=701&catid=56&subcat=1752
To me it seems sensible to go for the MSI one as its factory overclocked and has a good custom cooler on it meaning that overclocking further should be less of a problem.
On the other side i am aware that standard PCB boards can flash to 6970 bios and im presuming that the XFX is standard although it comes with stock cooler, would this card be more likely to flash then the MSI one?
Thank you for your help, wanting to get ordered to play some Witcher 2!
Also on a final thought, anyone know how well these fit into an Antec 300 case?
or
