6950 waterblock
IceQ X PLUS PCB
ocu9
IceQ X Turbo PCB
ocum
Appears to look the exact same so you should be able to fit a EK 6870 block to it
http://www.coolingconfigurator.com/
Can confirm that is the same PCB my XFX 695X-CNFC cards have, it is indeed a 6870 FC block that you will need. It uses one less screw than a standard 6870.
