no idea on how you got only 60c with the fan on auto , my 6970 hits 93c running msi kombuster . it idles at 40c with a room temp of 25c , also hits upto 91c while gaming . have i a faulty card ? , runs great apart from the temps
Hitting 90C on auto fan or even with a slighly modified fan profile is standard.
There are several threads similar to this where people report very low temps...they all end with a bunch of people who have perfectly normal cards wondering if their cards are actually borked.
Where someone posts temps this much lower either they are using a non stock fan profile or they are not measuring in realistic circumstances.
I think once afterburner supports voltage control things will be a lot more manageable- people with 6970s should be able to undervolt to 1.1v and shave a decent chunk off temps. (if most 6950s ll do 880 at 1.1v this stands to reason as the 6970s should be better cores).
Been gaming for around 10-12 hours today, max temp for my 6970 is 76 degrees, hotter than my 5870 but not that bad really, that's on auto fan and its very quite. Like this card a lot
the room temp is 15c,
This is how the op kept the temps down. To me is seems very cold room/house, im in the north east and i bloody freezing rad turned off in my office and still 22c room temps after an hour of gaming. Any way glad everyones happy and the temps are sorted![]()
if its cold tomorrow im going to overclock the i7 920 and 6970 within an inch of its life and go for a suicide run on 3dmark06 to see if i can break the 6k score
do you mean 60K or 6K ?![]()
