yeah 11.4 betaWhat drivers are best for the 6990? 11.4 beta?
Quad fire is hit and miss mate. Don't wanna spend any more moula
The 6990 runs HOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOT!
100% fans and 100degC during my run of Heaven 2.5 then! Man alive
My current config has the 6970 right next to the 6990, the latter of which is in the top 16x slot.
I think I am going to move the 6990 to the bottom 8x slot, giving it more air. I'll then move the 6970 to the top slot and put the Xonar/GT440 in the middle. That should help with temps
Here are some pics
Side by side with a 6970
Should I just say I have read the manual?
Side by side in the case - you can see the 6990 on top. I am going to change that now
You can also see that the 6990 only has one crossfire bridge connector. I have always used two, but whether to it like marmite! Some say do, some say don't. Now I can only use one
You can see the temps and GPU usage for Heaven 2.5 (using AIDA 64 and G19). This was taken around 30 seconds in, well before I say temps of 100degC and the fan automatically went up to 100!
what kind of lines? does it appear on dark images?@ Gareth, do you have trouble running 3DMark11 with tri-fire? I get weird lines, even with stock clocks? I have reinstalled the software app itself with no joy!
can u take a screenshot?
so whats it like then badboy? have you got the performance you were expecting in games?
im yet to fully tweak my setup because of sandybridge issue and lack of space for my 3 28's, but thinking now that my 2 6950's arnt going to hack 5760x1200 that well
if it's the slight scrolling bar flickering effect on dark images that im thinking of, i get it also on all games that as high fps.Weird flickering. Very strange. Not even clocked!
Yeah, I'll try to take some. Might just be me
do u honesty have that rig in your sig???go for quadfire like me teehee
no he doesn't......he's still at school and is a very naughty boy
he may be the next zzzac![]()
ever thought of watercooling?a complete watercooling kit and a 6970 plate is £200, and another £70 for the 6990 block, or stick some cardboard in between the cards or something because thats painfull!
