Hi,
I have a question regarding the 6pin cables and I would like your help please.
The one that comes from my PSU, has all 6 pins live.
However, the second extention I have is using 3 cables to connect on the molex and 5 pins are "live" inside the 6pin. For example this I use exactly.
http://overclockers.co.uk/showproduct.php?prodid=CB-018-AK&groupid=701&catid=48&subcat=153
While I had no issue with the 2x5770 setup, I have the feeling the 5850 doesn't get enough power.
I have connected the 2 4pin plugs, on their own lines straight from the PSU, without other devices taking power.
Is there any cable the provides power to all 6 pins through the 4ping plugs, or I need a new PSU to come with them?
Thank you very much.
