Hi all,
I'm helping my son build his first PC and have come across an issue.
Hes got a case with an RGB controller
https://www.amazon.co.uk/force-gami...=CIT+rgb+case&qid=1565808482&s=gateway&sr=8-4
The controller of which has 6 pin RGB connectors like these
https://images-na.ssl-images-amazon.com/images/I/61xaYZINUhL._SL1000_.jpg
The problem comes with the cooler:
https://www.amazon.co.uk/DEEPCOOL-W...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Which uses 4 pin connectors for the fans and pump.
Any suggestions on a solution, Ive had a look for 6pin to 4 pin adaptors but cant seem to find any.
Thanks
Thanks
