Hi All.
So I'm still running an AMD 7850, purchased many years ago and it's getting a little long in the tooth. CPU is the skylake i5 6600K, which isn't showing it's age quite as badly.
I'd like to upgrade the graphics card alone, but the powersupply I have is a Corsair CS550M. This provides 2x6 pin cables for the graphics card. As far as I can tell, everything seems to be using 8 pin as a minimum.
I really, really don't want to upgrade powersupply and graphics at the same time. But I can't see any good otherwise.
Have I missed something? Or am I just doomed to rebuilding the whole system in a few years, if the power supply doesn't melt first?
Thanks
The Very Slow Upgrader
Thanks
