Hi folks
Has anyone ever seen extensions for 6pin Pci power connectors?
Basically im using a TT Kandalf which as some people may know is a VERY tall case.
With the power supply at the top, the loom protrudes from the very top edge of the PSU itself, and with the GPU so far down, the twin 6pin Pci power connectors will not reach it!
Also i cannot flip the PSU around 180 degrees due to the screw mounts at the rear.
Fortunately i have used the supplied Molex-Pci converter loom to allow it to power, but this has left me with a hugh wad of ugly looking wires, also blocking part of my front panel fans flow!
Basically i need a female to male extension lead around 150mm long? Ive had a hunt around the net to no avail, just curious if anyone had come across anything as such?
