6pin PCIe convertors > 2 molexes.........why?
youshould find you have 1 male and 1 female molex connector 1 end goes on an existing molex (female ) leaaving you with 1 male connector to replace the one you have connected to.
Ah, that's the thing. ;)
Both connectors are male, so it's not a simple "pass through" lead.
ajgoodfellow said:
The 6 pin PCI-E power plug has two 12V rails. There is only one 12V rail per molex plug, hence the need for two molex plugs
But what if you connect it to the other molex connector on the same lead??
That's what i've done, no problems here, does seem weird :confused:
You're still getting 2 x 12v inputs.
