Trying to make a 6pin to 6pin cable to connect a GPU to an ASUS ROG motherboard (has both an 8 and 6 pin connector for GPU).
Found a couple of 2xmolex to 6pin PCI-e cables and was thinking of connecting them together after removing the molex connectors. Problem is that there are only 5 cables going in the 6pin connectors (it seems that the one missing is the "Sence"). Can I just connect the other cables?
[] X []
[] X []
