7 Degree temp differance between cores on Q9400, is this normal?
18 Oct 2002
North
If I prime95 I find that cores 0 and 2 are about 5-6 degs higher than the other 2... they also reach about 56degs too under stress at stock... is this too high for a quad? Idle they are 32-37 degs.
Its now running prime95 on 4 cores (blend) at 3.12ghz with no change in voltage and the temps are 61 56 60 56... is that ok for that speed?
Its an Akasa AK-965,. gets a bit noisy once temps get to 50 deg... the person i'm building it for wants a silent pc. I had it at 3.2ghz + and still on stock volts and prime stable... think I have clocker here.
