7-Zip v WinRaR
Permabanned
15 Sep 2006
Somewhere in York
I have both, when i try and open .rar or .01 .02 etc files sometimes z-zip complains about the file being broke etc, but yet with winrar it works fine.
Anyone know if i'm doing something wrong?
usually files that you have problems with are from an illegal source anyway
7zip is updated pretty often, and the newer releases tend to fix issues like this, try a newer release
I get that occasionally too, with the latest version.
No hardship tho, if it happens I just use WinRaR. Doesn't stop me using 7-Zip as my main compression utility.
I have both, when i try and open .rar or .01 .02 etc files sometimes z-zip complains about the file being broken
N00b. :p
If you have .01, .02, .nn, you unrar the .rar. If you have xxx.rar, you unrar the first one.
I use 7-zip exclusively and I've never had it fail on an uncorrupted archive.
N00b. :p
Well put it this way, the archive isnt corrupt since winrar can unrar it, but 7zip says there is an error.
That to me says 7zip is faulty in that respect.
other than 7zip throwing up the VERY occasional error decompressing illegally obtained multipart archives (usually .r01 .r02 .r03 etc...) it's perfect! and the shell integration is excellent.
ALZip will become Payfor in the future that's why i have switched to IZarc.
Thanks for pointing this out to me!
The link in the Useful Freeware Utilities thread has now been changed to a pre 1st December 2008 version, which also deals with .RARs...there are also other utilities in the list that deal with .RARs.
I get quite a few errors with 7-Zip but the fix for me is to use the "Copy To" option, it still says there's an error but unpacks the file anyway.
I haven't had to install anything else to unpack files in over a year so I'll carry on using it.
