70-200 vs 18-200
23 Nov 2007
Lancashire, UK
Noob question incoming!
I've taken the plunge and I'm learning about photography with a 100D I recently got from the MM here following a holiday in Iceland. Most questions I'm thinking of are generic ones and I can find claer answers, but not so this one (although I've found various articles giving me bits of the answers).
What's the practical difference between 70-200 and 18-200? From what I've managed to read, the 18-200 can struggle a bit in terms of image clarity due to the range it covers, and usually has a higher f-stop. Is that a fair summary of the differences, or is there more at play here?
Thanks.
It depends on what 70-200 or 18-200 lenses you're considering.
For Canon, their 70-200 lenses (F4, F4 IS, F2.8, F2.8 IS) are much better optically and mechanically (in terms of ergonomics and AF speed) than any 18-200 available. They're also much more expensive, and much heavier.
It also depends on what you're shooting and what you want to achieve.
A 18-200 lens is a compromise on image quality for the sake of convenience, generally. They're all going to be a lot softer at the telephoto end compared to a 70-200. I think something like the 15-85 would be a better choice as a walk around lens for Canon in Iceland. By that I mean, you're more likely to want something wider than 18 than you are to want longer than 85 for the types of shots I imagine you'll want to take there.
Of course, it all ultimately comes down to how seriously you want to take your new hobby :p
General consensus is that the Tamron and Sigma equivalent (18-270 PZD and 18-250 HSM OS) perform better than the Canon 18-200, if you decide a superzoom is worth the convenience. The new Tamron 16-300 is getting good reviews too, but it's a fair bit more expensive.
