700D Fans
17 Aug 2005
Swindon
I did a thread search and see others reporting of pretty poor temps in the case as standard.
Most people seem to recommend the Apaches as replacements.
If I have this right they are all 4 pin fans, the 4th wire being the one that controls the RPM of the fan.
If I use these in my case along with a Gigabyte x58 UD3R which only has 3 pin headers(?) they will run full throttle all the time?
How quiet are they in comparison to the stock fans? Will I notice much of a difference? Thinking of getting 2.
Possibly a push/pull config on the h50 and the standard 120mm corsair from the h50 being used as an exhaust on the top.
