Just trying to get the mobo loaded up and can't seat the PCI connectors closest to the slot area.
It's like the motherboard tray is too high up?
Is it that I need to bend the PCI bracket of each component such that it sits 'outside' the case?
Can't remember if the PCI blank covers that came with the case were installed like this, though I do remember them popping off strongly when taking them off.
I don't think its the thin vinyl i've applied causing the problem...
Anyone?
No worries, je suir en retardez
I HAD covered up a small PCI 'well' beneath each slot with my carbon vinyl. Slit with a scalpel they go in fine now
False alarm, back to the loop...
Anyone?
