Be Quiet700W Gold what? Should be ok if its a decent psu.[
Straight Power 10 700wWhat model and how old is it?
Thankyou.It has 672w across it's quad 12v rails so it should be ok but just to be sure use two seperate pci-e leads to power the card and not the pair that are daisy chained on a single lead. I would hold on for a while though as there appears to be a 20Gb 3080 coming although no doubt it will be even more expensive and suck even more power. See here.
In terms of this daisy chaining I checked my cable and wow your right! It’s two 8 pin heads coming from one pcie power slot on the PSU.It has 672w across it's quad 12v rails so it should be ok but just to be sure use two seperate pci-e leads to power the card and not the pair that are daisy chained on a single lead. I would hold on for a while though as there appears to be a 20Gb 3080 coming although no doubt it will be even more expensive and suck even more power. See here.
Thankyou. Yes I think I can stick with my psu just need to sort the cable situation out!Should be more than enough.
This guy has a 600W PSU and works fine.
https://www.reddit.com/r/nvidia/comments/ixc9pb/rtx3080_3700x_600w_psu_power_draw_results/
It’s going to look a bit ugly in my case if I use a second set and have two Unconnected 8pin plugs ‘Flapping’ around, can these power leads be bought individually where they don’t split?
So I shouldn’t use just this cable in the image instead use two of these , using one set of 8pin plugs from each? If so I could always cut one set of and shrink wrap itI have always used braided cable extensions so that the daisy chained connector is out of sight. I just plug the extension into the primary connector and have never had any problems. My current psu though has individual pci-e leads so no daisy chaining going on.
