720 temps
10 Aug 2009
Malvern
Been runnin my amd 720 as a quad now for about 3 months or so no problems with a mild overclock of 3440ghz,anybody no of a way to check temps of cpu cores ?coretemp dont work when the 4th core is unlocked and as far as i know nothing else does either, only thing i can do is check my mobo temp off pc wizard!anybody no of any new software out that will show my temps?
CPU temp will usually be the better temperature to monitor not core temp as apparently core temps are software generated in AMD phenom's. CPU temp is usually TMPIN0 or TMPIN1 in "Hardware Monitor" that is the the correct value to check.
You can't on an unlocked CPU I found my core temps are around 7C lower on idle and and 10C lower at full load you could lock the core to check.
