BillytheImpaler said:The memory is DDR, double data rate. It's rated speed is double its frequency. That's why the DDR400 in the system I'm using to post this only really runs at 200 MHz. Your current memory clock is 1648 MHz, a significant overclock from the stock frequency.
Thorpy said:by idle do you mean just browsing the web then yes.
amd 3800 dual core stock cooler
damn artic cooler wont fit >_<
feriso said:ChristYou got a helicopter in there, look at Fan3 20,000 rpm.......
The freezer should fit mate as its AM2 compatible.
